Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
Where is the heated mirror switch for the Volvo S40?
My Volvo S40's battery seems fine. Why does the electrical system show a fault, and it starts smoking as soon as I start it? We've checked but can't find what's wrong.
Has anyone experienced occasional power loss with a 2006 Volvo S40? Sometimes the car loses power even when just listening to music.
4How do you start the ignition of a Volvo S40? The key looks like plastic. [shy]
5If both the person and the key are inside the car, does the electronic anti-theft indicator on the dashboard still flash normally?
6The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
7Guys, can you help me figure out what I need to replace here? It's giving me a headache!!! "Jeep Liberty reports C121C Torque Request Signal Denied, first issue." "Crankshaft/Camshaft Timing Misalignment - Bank 1 Sensor 1 - Powertrain Control Module (PCM) fault code: P0016, this is the second issue." "Camshaft Position Sensor Circuit - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0365, this is the third issue." "Camshaft Position Sensor Intermittent - Bank 1 Sensor 2 - Powertrain Control Module (PCM) fault code: P0369." "Bank 1 Camshaft 2 Position Slow Response - Powertrain Control Module (PCM) fault code: P000B." "Torque Request Signal Denied - Anti-lock Braking System (ABS) fault code: C121C."
8It sounds like you're experiencing an issue with your 2012 Peugeot 308 not starting, and you're hearing a clicking sound with the onboard computer resetting. Since the battery has been tested and has power, the problem could be related to the starter motor or its connections, the ignition switch, or a potential issue with the car's electrical system, such as a bad ground or corroded terminals. It's recommended to have a professional mechanic check these components to diagnose the exact issue.
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
