If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
The trunk won't open, what's going on?
Can you only open your trunk using the key?
The trunk of the S40 won't open, what's the issue?
4Where is the button to open the trunk if it won't open?
5If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
6When you open the door of a Sportage, do the hazard lights flash?
7The trunk of my Rapid won't open. Is there a solution?
8Hey guys, does anyone know why the trunk can be opened with the key but not by pressing the button?
9What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
10Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
