I just bought a small Volvo, 2008 model. The condition is pretty good, but the shock absorber springs are too hard. Have any of you experts replaced them, or know which other cars have compatible parts? Thanks!
I have a 2009 Toyota Yaris 1.6 automatic. Recently, the car has been making strange noises. It sounds like a spring or shock absorber is out of place. Does anyone know what the issue might be? Is it serious?
4I want to buy one. Does this small city have the parts?
5Do any of you with the old 2012 model of Changan Yuexiang have issues with rear wheel shock absorber top corrosion and rust, leading to the shock absorber falling off? If you do, please type 1, thank you.
6Hey guys, how much does a pair of original V97 shock absorbers cost, and where can I buy them?
72020 model 1.5L, used for 3 years, just one small issue: there's a strange noise in the back of the car. Not exactly sure where, but it sounds like a spring being compressed or maybe two small metal parts rubbing against each other. Hard to describe... Has anyone experienced this? Any suggestions?
8Looking to modify the shock absorber, does anyone have the wiring layout diagram for this car?
9I bought a 2007 1.6 automatic luxury model for 16,000 in 2022. It was noisy and not easy to drive, so I ended up spending 12,000 on it gradually. I replaced the shock absorbers, engine mounts, stabilizer bar, light bulbs, bearings, and cleaned the engine—pretty much everything that needed fixing. It's much better to drive now and feels like it can last a few more years. I have to say, the parts are really cheap. The city fuel consumption averages 8.8, and I drive pretty aggressively.
10Does anyone know if the shock absorbers for the 2.5 imported Koleos are compatible with those of the X-Trail?
