أحمد خلف
2022-10-14 22:21
How do you charge your phone? The cigarette lighter USB can't charge my iPhone, but it works with OPPO. Does anyone have any solutions?
Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
My HS's electronic start-stop function isn't working. Is there any solution?
The USB port in the armrest of a 2012 GLS can't charge your phone. Are there any other places to charge your phone?
USB upgrade for Venus shows "USB not found." The USB is already plugged in next to the cigarette lighter.
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
Hey fellow car owners, does the 07 Lexus IS 250 (low trim without screen) have a BLIS system? Also, is there a USB port, and where's the cigarette lighter located?
My iPhone 15 Pro Max can't connect to the car's system via Wi-Fi, but when I went to the shop, the technician was able to connect other brand phones without any issue. Does anyone have a solution for this?
The wireless charging on my phone is very hot and it's not charging.
Can the USB port in the car be used just for charging? Why can't it connect to the car's infotainment system?
The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
Volvo Volvo S40
Volvo S40TBDPetrol
