سلمان دليل
2021-06-13 14:57
Hi everyone, I need some advice. I have a 2011 Volvo S40, and after parking, when I shift from D to P, I can't remove the key. I have to restart the engine, reverse, then go forward, and try parking again. Sometimes it takes several tries before I can remove the key. Is this a transmission issue or something else?
أحمد مجدي
أحمد مجدي2021-12-20 20:53
There is a Hall sensor under the gear lever, and it's the one that malfunctioned. It detects the gear position, which means sometimes it can't detect if the gear lever is in the "P" position.
عمر حليم
عمر حليم2021-08-31 11:12
I have the same issue. Did you manage to resolve yours? How did you fix it? Mine isn't working manually either! [Facepalm]
حسين عثمان
حسين عثمان2021-07-06 12:48
Check the dust cover below the gear lever.
حسن كاظم
حسن كاظم2021-06-17 22:35
Transmission and louvers need to be checked using a computer.
حسن كاظم
حسن كاظم2021-06-17 22:32
The gear didn't shift over.
