عبد العزيز يوسف
2024-05-17 21:13
When I went to refuel, the fuel cap wouldn't open after I parked. I couldn't press the brake when starting the car, and it also showed an engine fault warning. It took seven or eight tries to get a response. What's going on? Any ideas?
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
I have a 2015 manual car, and there is a slight clicking sound when refueling. How can this be addressed?
I recently took my 2021 manual 1.6 35p to the dealership to replace the clutch pedal. After coming back, I noticed that when I lock the car, the indicator lights flash rapidly six or seven times. Previously, they would flash slowly twice. Additionally, there's a warning about low key battery, but the key can still control the car from a distance. What's going on?
Hey fellow car enthusiasts, I have a question. My car has been parked for over a month, and when I tried to start it last night, it started up but the air conditioning wouldn't turn on. Anyone with expertise know what might be going on?
Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
Gear won't engage. Every time this happens, I just turn off the car, wait a bit, then restart, and it goes back to normal. Took it to the repair shop, but they couldn't find any issues.
I have a 2016 automatic Santana, and the ABS light occasionally turns on and off. When I took it for a check-up, they said there was no problem, and it drives fine. It's just annoying to see the light on. Any idea what's going on?
I just bought a new manual 4WD Night Eagle, and after driving just over a thousand kilometers, there are all sorts of strange noises. I've been to the service center seven or eight times, and it's still not fixed. I'm really frustrated! Does anyone know what these noises could be? It's a new car, what should I do with it?!
Does your car make a creaking noise on bumpy roads? I took mine to the service center, but they couldn't find anything. Does anyone else have this issue?
MG MG RX5
MG RX5AED 82,400 ~ 95,000Gasoline
