عبدالرحمن أبشير
عبدالرحمن أبشير
Jun 17
This morning, when I started my car, it showed a fault: "Electronic shift backup activated." What does this mean? Can anyone help explain?
فهد جمال الدين
فهد جمال الدين2024-08-16 17:56
Disconnect one side of the battery cable, wait for about five minutes, and then reconnect it.
علي يعقوبي
علي يعقوبي2024-06-22 17:54
The electronic gear shift module is faulty. The backup is activated. Get the module replaced as soon as possible, otherwise, you might find yourself stranded one day.
My E3 is having trouble starting in the morning. What could be the issue?
"The electronic shift backup has been activated; please service soon." This message indicates that there might be an issue with the electronic gear shifting system in your vehicle. It's recommended to have it checked and serviced by a professional as soon as possible to avoid potential problems.
My Volvo S40's battery seems fine. Why does the electrical system show a fault, and it starts smoking as soon as I start it? We've checked but can't find what's wrong.
Can anyone help with how to activate the lane assist feature?
Do you guys have issues with the passenger airbag showing error codes? Mine was fine in the morning, but in the afternoon, it started showing an error code. Have you experienced this?
My H7 sometimes shows an ESP fault when I start the car directly. Do any of you fellow car enthusiasts experience this situation?
My HS's electronic start-stop function isn't working. Is there any solution?
I ordered the 2024 X version in-stock car, and it shows Santorini Black. But I see the 2024 models are called Meteorite Black. Why are they different? Can anyone help explain my confusion? 😊
Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
MG RX5
MG RX5EGP 319,990 ~ 1,500,000Gasoline & Petrol
