The original spark plug failed after just over 10,000 kilometers. How about you guys?
Hey guys, at how many kilometers did you change your spark plugs? 😎
Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
4Is it normal for the rear wheel bearing to fail after 37,000 kilometers?
5I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
6The original spark plug failed after just over 10,000 kilometers. How about you guys?
7Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
8I'm thinking about changing my spark plugs recently. What brands do you guys use?
9Hey everyone, at how many kilometers did you replace your car's original spark plugs? I'm at 80,000 km now, and the car starts up instantly. Not sure if I should replace them.
10My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
