"The electronic shift backup has been activated; please service soon." This message indicates that there might be an issue with the electronic gear shifting system in your vehicle. It's recommended to have it checked and serviced by a professional as soon as possible to avoid potential problems.
If the car wasn't completely stopped before shifting into reverse and you heard a grinding noise, it could potentially cause damage. It's generally recommended to ensure the vehicle is fully stationary before changing gears to avoid any harm to the transmission system.
4I've had my car for a week, and the 4S dealership has forwarded my personal and vehicle information to the manufacturer to activate the customer service. But when I try to connect to the customer service phone from the car, it doesn't link up. Has anyone experienced a similar issue? If you know anything, please reply, thanks!
5The message "Reduced Engine Performance" on your car usually indicates there's a problem that needs attention. This could be due to several reasons, such as issues with the fuel system, air intake, or engine sensors. The fact that the car stalls at low speeds suggests it might be a problem affecting the engine's idle function or fuel delivery. It would be best to have it diagnosed by a professional to pinpoint the exact cause.
6If the car is already started, you can usually drive it even if the key is not inside. However, most modern cars will give a warning sound or display a message indicating that the key is not in the vehicle. This is to alert the driver that the key might be missing. As a chauffeur, if you reach the destination and the owner cannot find the key, it's important to inform them about the situation.
7When the MINI is in D gear and you brake, if there's a prompt to shift the transmission to P gear, there might be a couple of reasons for this. It could be an issue with the gearbox or a safety feature that's activating. If the car doesn't move when you release the brake, it might be due to a malfunction or an electronic system engaging to prevent movement. It's best to consult the vehicle's manual or contact a professional mechanic to diagnose the issue accurately.
8This morning, when I started my car, it showed a fault: "Electronic shift backup activated." What does this mean? Can anyone help explain?
9I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
10When driving on the highway, if the steering wheel starts vibrating when you exceed 100 km/h and the vibration becomes more pronounced at 120 km/h, it could indicate a few potential issues. It might be related to wheel balancing, alignment, or tire issues. You might want to have these checked by a professional to ensure safety.
