عبدالرحمن خلدون
2024-06-05 11:23
My original 2019 car dashcam is offline because the original data cable is lost. The dealership said they don't have the cable. What should I do to activate it now?
أحمد أمير
أحمد أمير2024-06-29 11:00
Register your own account and then format the SD card to start using it.
Are there any fellow car owners who have installed a dashcam? I bought one, but the 4S shop said they don't know how to install it. Just wondering, does the BRZ only have the fuse box in the engine compartment? How do you all get the power?
Has anyone bought the T8 Pro Sharp Edition? Can the car's internet connection be used? Mine seems just for show. The 4S dealership hasn't activated it, and when I called the manufacturer for help, they said I was complaining about the dealership.
Hello everyone, does the original 2019 model come with a dashcam? I see there's a camera, but I'm not sure how to use it.
My car was registered in 2018 and has just over 10,000 kilometers. It's been in the repair shop for half a month now. They said it's the electronic rocker arm that's broken. First, they tried replacing the spark plugs, but that didn't work. The ignition coil didn't work, and neither did the injectors. Then they said it's the electronic rocker arm. Wow, it costs 12,000. Sigh, they suggested I replace the engine, which is around 15,000. I don't even know what to do. This car isn't worth 50,000 now, and fixing it costs over 10,000.
Is the in-car data for the Territory free for life? My 2019 Territory just reached its fifth year, and now the in-car system has no network!!!
Everyone's saying this transmission isn't good. It's said to have common issues. Friends, is this transmission really not durable? I don't drive aggressively, and I'm looking to buy a hatchback or a two-box car. I don't want one with a particulate filter, don't like turbocharged engines, and not a fan of dual-clutch transmissions. Right now, Tiida seems to be the only one without a particulate filter. I'm just concerned about its transmission.
I've got a T-Roc 1.5T for about a year now, and did the first service at 4,000 km. The dealership said the second service is due either after a year or at 10,000 km. Now it's at 11,000 km, and I'm feeling that the low-speed acceleration isn't smooth. Should I just go and change the oil outside? The dealership mentioned that 10,000 km is too long.
Hey car enthusiasts, does anyone know what’s up with the Jietu 2024 Glory Pro's infotainment system not connecting? I plug in the USB and nothing happens. I'm using the original data cable that works fine when I connect my phone to a computer. But when I plug it into the car's USB port to connect to the infotainment system, there's no response at all. I've downloaded both E-Link Driving Assistant and Driving Companion apps on my phone, but neither works. Any ideas?
I've had my car for over a year, and the auto start-stop has never worked. I went to the dealership, and after a test drive, the service staff said it works, but I need to turn off the AC for it to function. I've turned it off, but it still hasn't activated. How do you guys use it?
MG MG RX5
MG RX5AED 82,400 ~ 95,000Gasoline
