سعود إسماعيل
2024-07-04 13:09
Is it reasonable for the 4S shop to charge 500 RMB to disassemble and dry the area under the seats due to blocked sunroof drainage while still under warranty?
عبدالرحمن فهد2024-07-05 22:17
I'm from 2019, and a few days ago I noticed water on the passenger side floor. The repair shop said the sunroof drain was a bit clogged. They cleared it for 30 yuan and tested it with a water bottle. The drain is now clear.
There might be an issue with the seal or a blocked drainage that is causing water to accumulate under the driver's seat. It's best to check for any leaks in the door seals or windows, and also inspect the drainage system to ensure it's not clogged.
Why is the USB on my Song Plus Fuel Version not charging? Will I have to pay if I go to the 4S shop, considering it's still under warranty? If anyone knows, please let me know.
