I'm planning to change my tires. Does anyone have cheaper sources for Michelin? I need to replace all four. [Facepalm][Facepalm]
Hey car enthusiasts, my car's almost at 60,000 km and I'm planning to change the tires. Any recommendations for ones with good value for money?
Hi everyone, what model and size of tires are you using for your City? I'm planning to replace mine soon, any recommendations?
I'm not sure why your tires appear underinflated, especially the front ones, even though all four tires are at 250 kPa.
4I'm planning to change my tires. Does anyone have cheaper sources for Michelin? I need to replace all four. [Facepalm][Facepalm]
5Car enthusiasts: If one fuel injector is broken, can I just replace that one, or do I need to replace all four?
6My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
7Is it necessary to change the tires? They've been used for 3 years and 60,000 kilometers, and I'm planning to go on a long road trip.
8Is it necessary to change the tires? 3 years and 60,000 kilometers, planning to go on a long trip.
9Why do my Ariya tires need to be inflated every week? All four tires are losing air. I inflated them to 270 kPa, but after a week, they're only at 250-260 kPa.
10Has anyone here modified their car or changed tires? My left front tire got a nail in it and can't be repaired. I've been asking around but can't find a Toyo 225 55 R19 tire, and with the national holiday, I can't replace it until the 4th. It's really inconvenient. Has anyone switched to other tire brands after buying their car? Any recommendations? I'm hesitant to replace just one tire with a different brand, and since I need the car urgently, I'm considering replacing both front tires.
