سلمان يحيى
Aug 19
Hey friends, when the car is running, it shakes. I did a front wheel balancing, but it still feels a bit shaky. What could be the reason?
When the car is idling, it feels like it's shaking, but when I shift to neutral, it doesn't. Does anyone know what might be the reason?
After replacing the front suspension arms on my 2014 compact car, the steering wheel feels much lighter and not as stable as before. I took it to a repair shop, and they changed the valve core, saying it was a tire pressure issue. However, the light steering feel returned shortly after. I've already done wheel alignment and balancing, but haven't changed the power steering fluid. What could be the reason for this?
4Are there any friends who feel that the front seats, especially the driver's seat, are too narrow for those who are on the heavier side?
5The engine feels sluggish and powerless after running over 100,000 kilometers. Does anyone know the reason?
6I have a 2018 Outlander 2.4 AWD. Last month, the right front wheel got hit, and I had to replace the shock absorber, half shaft, and steering rack. 😒😒😒 Now, when I'm driving at around 110 km/h, the steering wheel vibrates in my hands. It's not exactly a shake, but more of a tingling feeling. The car doesn't drift or vibrate, just the steering wheel. If I grip the wheel tightly, it feels a bit better. There's no issue when driving below 100 km/h. I've done wheel alignment, and the data is spot on. I've also done wheel balancing and swapped the front and rear tires. I've even replaced the front bearings, but there's no change. The repair shop said the next step would be to start replacing parts one by one, but that would be too costly. Does anyone know what the problem might be? I'd be willing to offer a small reward for a solution. 😏😏😏
7My car has run 50,000 kilometers, and now I notice it starts to shake when reaching speeds of 80 to 100 km/h. I've already done wheel balancing, and the throttle body was cleaned six months ago. Does anyone know how to solve this? Please help!
8My car has run 50,000 kilometers, and now I notice it starts to shake when reaching speeds of 80 to 100 km/h. I've already done the wheel balancing and cleaned the throttle body six months ago. Does anyone know how to solve this? Please help.
9Why does the 2016 308 1.2T automatic feel a bit shaky in higher gears? Could it be due to insufficient engine torque? Do fellow car enthusiasts experience the same issue?
10Hey friends, when the car is running, it shakes. I did a front wheel balancing, but it still feels a bit shaky. What could be the reason?
