عمر ذكي
2024-05-20 19:04
Does anyone know if it's possible to set the default to economy mode? My fuel consumption is too high, and I want to try driving in economy mode for a while. 🤦‍♂️
فهد فارس
فهد فارس2024-05-23 12:06
Just use electrical tape to cover it up, and it won't be visible.
عبدالرحمن فهد
عبدالرحمن فهد2024-05-23 10:37
Fuel economy is decent only on the highway, but in congested city conditions, it's basically 12+.
عبدالله باسل
عبدالله باسل2024-05-21 18:25
Once you buy this car, don't worry about the fuel consumption.
علي مأمون
علي مأمون2024-05-21 11:17
The Roewe RX5 MAX consumes fuel in any mode [I want to be quiet] and the transmission isn't smart [grinning].
What's the fuel consumption for your 1.6G Yaris? Is a 10L consumption too high for such a small car?
Hey guys, how's the fuel economy on your 2.0T flagship models? I plan to secretly buy a car for my dad, but he can't handle high fuel consumption. [Frustrated] Please share the real fuel economy for city driving!
Is the fuel consumption of the 1.8T GA6 high or not? Some people say it's high, while others say it's normal!
When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
It's hard to find a dealer to test drive this car now, huh? I wanted to try it out too.
I heard that the fuel consumption of the 4WD petrol version is higher than the 2WD. How much higher is it? Can the 4WD version switch to economy mode to achieve full 2WD?
Is it possible to set the car to default to internal circulation instead of external circulation when starting?
Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
Is there a 2019 version of the Arrizo 5 CVT? My fuel consumption is consistently between 8.4-8.8, which is too high.
MG MG RX5
MG RX5AED 82,400 ~ 95,000Gasoline
