Do you need a wheel alignment after fixing a tire? My car shakes at speeds over 100 after a tire repair. What's going on? Can anyone help?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
Does your steering wheel shake a lot when you brake at speeds over 60? Have any of you experienced this phenomenon?
I have a 2015 Kia Sportage. The steering wheel starts to shake when I go over 120 km/h. What's going on? Can anyone help?
4My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
5My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
6Driving over speed bumps at 60 km/h can indeed have an impact on your car. It might cause stress to the suspension system, tires, and potentially the alignment. It's always best to slow down for speed bumps to avoid any potential damage.
7Do you need a wheel alignment after fixing a tire? My car shakes at speeds over 100 after a tire repair. What's going on? Can anyone help?
8It sounds like you are experiencing a vibration issue with your vehicle, especially noticeable at certain speeds. After performing wheel balancing, the shaking became more pronounced between 100 to 110 km/h, even reaching the seats, but it disappears at 120 km/h. You also mentioned that at low speeds on uneven cement roads, there is a resonance from the engine compartment to the steering wheel. These symptoms might indicate an issue with the wheel alignment, tire condition, or suspension components. It would be advisable to have a professional mechanic inspect the vehicle to diagnose and resolve the problem accurately.
9Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦♂️
10The steering wheel is crooked 🤦♂️. Even after doing a wheel alignment, it can't be fixed. The mechanic said it's caused by a deformed lower control arm?
