If we compare the base models, which one is better, the 300 or the 350 Yuexiang? Some people say the hybrid is the core, but the 300 has full-time four-wheel drive. Here, the Yuexiang is a few thousand more expensive than the 300. 😢
Comments( 8 )
فهد إسحاق2024-11-20 15:10
The four-wheel drive can be completely ignored.
خالد صلاح الدين2024-11-20 13:36
Definitely go for hybrid unless you're really into pure gasoline engines. Toyota doesn't have a single good mass-produced turbo engine. If you want turbo, go for German brands; otherwise, stick with Toyota.
محمد نواف2024-11-18 23:18
The 300 model tends to have a common issue with the fuel injectors needing replacement later on, which can be more expensive to repair than the battery and even requires lifting the engine. You might as well consider the 350. If you're thinking about the 300, you might as well add a bit more and go for the Q7 2.0.
أحمد بشر2024-11-18 20:37
The small screen on the 300 looks really ugly.
عبدالله خلف2024-11-18 14:08
How much is it on the road now?
خالد أمين2024-11-18 10:26
High mileage, go hybrid.
حسن عرفات2024-11-18 09:22
On the highway, go full throttle up to 300 km/h, and in the city, use the hybrid mode more often.
نايف عرفات2024-11-18 01:31
I mostly drive on the highway and I'm planning to check out the 300 by the end of the month. Not sure if there are any discounts available right now.
