When the engine is idling, the RPM is stable at around 800. However, when you press the clutch and shift gears, the RPM increases to 1200 (without releasing the clutch, just purely shifting gears). What could be the reason for this? (The transmission, clutch, and flywheel have been checked and there are no abnormalities.) Car model: Manual rear-wheel drive Mazda 6-speed manual RX-8 Type S.
When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
Hey guys, I have a 1.6 manual Liana. At what RPM do you usually shift gears?
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
4Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
5Has anyone experienced any abnormal noise when shifting gears with the 1.4T transmission? It's only at 28,000 kilometers.
6What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
7Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
82017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
9Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
10How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
