What formats of USB drives are supported by the 2017 Jeep Renegade?
I bought a music USB online, but my car can't read it. What format should I change it to?
What formats does the 2017 Jeep Renegade support for USB drives and music files?
4What type of oil does the Jeep Renegade 1.6 1.4T use?
5Is the timing on the 2017 1.4T Jeep Renegade a chain or a belt?
6What brand of loudspeaker does the Jeep Renegade use?
7What do you think about the Jeep Renegade?
8What type of oil does the Jeep Renegade use?
9There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
10What formats does the USB interface support? I'm planning to use a USB drive to play lossless music, and I'm not sure if it supports APE format.
