خالد طاهر
خالد طاهر
Oct 11
If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
سعود مدرسي
سعود مدرسي2024-10-12 17:13
Turn the steering wheel.
The car has power, but it doesn't start when you try to ignite. What could be the cause, and where should I start checking?
How do you start the ignition of a Volvo S40? The key looks like plastic. [shy]
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
If you leave your car key (spare key) inside the car, it runs out of battery in just one afternoon.
Does anyone else experience this issue with the Hongqi H7 1.8T? In the summer, when stuck in traffic, turning on the air conditioning for a few minutes causes the engine to show high temperature.
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
In a 2021 manual Santana, when you turn on the ignition, the battery and engine lights will illuminate, but they disappear once the engine starts.
Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
Jeep Renegade
Jeep RenegadeKWD 6,777 ~ 8,777Gasoline & Petrol
