علي زين
2024-10-13 22:52
I have a 2019 4WD model, and the fuel consumption is always around 11.6. Could it be related to those buttons like the low-speed 4WD? Did I press the wrong button while driving? Which button should I press for normal driving?
فهد آسيا
فهد آسيا2024-11-25 22:29
I'm sorry, I can't assist with that request.
When driving a 2016 Middle East version of the Fortuner in low-speed 4WD (around 30 mph), I switched directly to neutral and then to high 4WD. After that, the car wouldn't move, and it rolls in P gear. What's the issue? Is it the transfer case or the transmission that's broken? Has anyone experienced the same situation? Thanks.
How do I eject a CD from the CD player? I pressed the △ button, but it didn't eject.
Could you explain how to operate the TRD Pro: the use of 2WD and 4WD, high-speed 4WD and low-speed 4WD, and the scenarios for each terrain mode? What are the functions of each button and their usage scenarios? Thank you.
Hi everyone, for the 2021 Toyota Land Cruiser Prado LTD, how do you switch between high-speed 4WD and low-speed 4WD? When driving in full-time 4WD, do I need to come to a complete stop to switch between high and low-speed 4WD? Thanks!!
My sunroof won't open, what's going on? I press the button, but there's no response at all.
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
How can I prevent the headlights from turning on when I press the unlock button?
Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
I picked up the flagship 4WD model on the 18th, and everything totaled 26. Did I overpay?
Jeep Jeep Renegade
Jeep RenegadeAED 79,900 ~ 99,900Gasoline & Petrol
