علي زين
2024-06-20 16:43
I accidentally hit the curb with my left rear wheel and the tire got damaged. During the four-wheel alignment, they said it couldn't be fully adjusted. If the tire is damaged, does it really require changing the shock absorber? Is it really that serious?
خالد حافظ
خالد حافظ2024-06-29 22:10
Could you take a photo of the original car towing hook? I lost mine and need to buy a similar one, thanks.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I have a 2009 Toyota Yaris 1.6 automatic. Recently, the car has been making strange noises. It sounds like a spring or shock absorber is out of place. Does anyone know what the issue might be? Is it serious?
Do any of you with the old 2012 model of Changan Yuexiang have issues with rear wheel shock absorber top corrosion and rust, leading to the shock absorber falling off? If you do, please type 1, thank you.
After changing to new tires, the steering feels heavier. I always used Continental CPC2, but switched to Goodyear Assurance (also did a wheel alignment). It doesn't veer off course, but the steering feels heavier, and the accelerator is also heavier. For those who've changed tires, how do you feel about it? Also, a reminder: wheel alignment is a maintenance service, not mandatory. If you choose to do it, make sure to check the shop's equipment and skills. I feel it wasn't really necessary this time.
Hello, car enthusiasts group. When swapping the positions of all four tires, is it necessary to do wheel balancing and alignment?
Has anyone replaced the shock absorber bushings or other bushings on a 2015 Jetta? As for the engine mount rubber, if it's not severely damaged, should I continue using it?
Do you need a wheel alignment after fixing a tire? My car shakes at speeds over 100 after a tire repair. What's going on? Can anyone help?
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Has anyone done a wheel alignment? My City has uneven wear on the left rear tire and slightly pulls to one side. I've heard that the City’s rear wheels are non-adjustable and you can only add shims during alignment. Is this safe? Also, is it necessary to do a wheel alignment since the tires are quite cheap? 🤦‍♂️
Jeep Jeep Renegade
Jeep RenegadeAED 79,900 ~ 99,900Gasoline & Petrol
