Hey guys, can the 2018 standard Renegade fit an 8.4-inch infotainment screen? I saw a non-4WD Renegade with an 8.4-inch screen too. 🤦♂️
I have a 2018 2.0 4WD Jeep Renegade. When I start the car, while the gear is in the P position and I press the brake, I hear a clicking sound from the gear area. Has anyone else experienced the same issue?
Switching from 92 to 95 octane gasoline for your 2018 Jeep Renegade 4WD model might be beneficial for the engine.
4If you're considering buying a used Polestar, whether it's the 2020 launch edition or the 2021 standard or long-range version, it's important to weigh your options. Since you mentioned that you're just looking for a used car to play around with and only need a range of over 200 km, and you're not too concerned about the car's infotainment system, both options could work for you. Each model year has its own set of issues, so I suggest checking the specific car's condition and history. Also, be sure to look into battery health, as that will affect the range. Happy hunting! 😄
