Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
2008 Yaris 1.6 automatic, driven 130,000 km. Now, when the engine is cold, it can't shift from 3rd to 4th gear, and it can't accelerate beyond 70 km/h.
The car makes a buzzing noise when driving over 80 km/h.
When driving a manual 1.5L Mazda in fifth gear at 80 km/h, what is your engine's RPM?
4Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
5Are there any T-Cross owners here? Is your car shifting smoothly? I feel like my gear shifts are quite slow.
6What could be causing the hesitation at 80 km/h in an Elysion?
7Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
8When driving at speeds between 80 and 90 km/h, the car's chassis vibrates, but it becomes smooth again at speeds of 100 km/h. What could be the reason for this?
9When merging onto the highway with a CX-30 MT, which gear do you use to accelerate? From 50-80 km/h, there's not much power in 4th to 6th gear. Do you need to rev it up to 100 in 3rd gear?
10Why has there been frequent gear lag recently? It's a 2019 model with a 1.4T dry dual-clutch. After picking up speed and then braking, the gear doesn't match the speed. For instance, it's in 6th gear at 45 km/h and 5th gear at 35 km/h, but it doesn't downshift further. It upshifts quite eagerly. Went to the 4S shop, and they said the engine isn't strong enough, and the gearbox can't be adjusted?
