عمر خلوق
2024-02-09 21:41
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
نايف عمرو
نايف عمرو2024-07-22 09:57
That's exactly the same as mine. [I want to be quiet] [I want to be quiet]
أحمد داود
أحمد داود2024-07-14 03:35
Issue with the Wheel Speed Sensor
أحمد خليل
أحمد خليل2024-05-08 17:43
How did you fix it later, like I did?
How to solve the issue of the car rolling back even with hill-start assist?
Does the 2012 1.6 manual Yizhi have a hill-start assist feature? Where can it be activated?
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
After the light came on, I drove 20 kilometers and then refueled 65 liters. I'm starting to doubt if my fuel tank is actually 80 liters.
Jeep Jeep Renegade
Jeep RenegadeAED 79,900 ~ 99,900Gasoline & Petrol
