Why is the USB in Koleos not powering up? It won't connect.
Why is there no data for Koleos' tire pressure monitoring?
Why is the front USB port sometimes powered and sometimes not, even after the 4S shop replaced it with a new one?
Why won't the trunk and sunshade lift up?
4Can the 2018 Renault Koleos play lossless music from a USB drive?
5Why is the USB port in my Koleos not powered?
6Why is the USB in Koleos not powering up? It won't connect.
7Does anyone know why the rear window won't go up or down? Thanks!
8Can the USB port in the car be used just for charging? Why can't it connect to the car's infotainment system?
9The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
10Why can't my newly purchased USB drive be read and why does it show as not connected?
