Which coolant should I buy for the imported Koleos? I noticed today that the coolant in the reservoir is below the minimum line and I'm considering replacing it all. Could you advise on which coolant would be suitable?
I'm considering buying a car for Didi. Which electric vehicles would be suitable for this purpose? What do you guys think?
When driving the 2014 Foton Tunland 2.8S 4WD, there is a noticeable humming vibration in the cabin when the alternator speed is below 1600 RPM. However, once the engine speed reaches 2000 RPM, the humming sound disappears. Could any experts advise on what might be causing this issue?
Hello everyone, can anyone advise on which brand and model of transmission oil is suitable for a 2013 Phaeton 3.0, non-turbo version? How can I ensure I'm buying genuine products? Also, is there any suitable option from Mobil for this? Thanks.
4Is the Scirocco really that problematic? Do the engines need frequent repairs? And do things like spark plugs often fail too? I'm considering getting a 2.0 or an R model. Can any car experts advise on which year model is more suitable?
5Which coolant should I buy for the imported Koleos? I noticed today that the coolant in the reservoir is below the minimum line and I'm considering replacing it all. Could you advise on which coolant would be suitable?
6After watching the "Initial D" movie, I noticed a problem. Takumi's dad put an illegal engine in the 86, but Ryosuke and Kyoichi's cars have large horsepower from the factory, which should be legal engines. In fact, in the movie, there's a line saying, "The FC's horsepower is too high, although it's limited to 250...," indicating they even restricted the power. So, did Takumi cheat?
7I'd like to ask everyone here, what are the wheel parameters for the Brilliance V3, and how much does each one weigh approximately? Also, if I want to reduce the unsprung weight without changing the size of the Brilliance V3's wheels, which brands of wheels would be suitable?
8Hi everyone, I'm considering buying a Jeep Compass around 14.15. I'll use it for daily commuting. Is the only difference between the 2.0 and 2.4 models the two-wheel drive and four-wheel drive? Which one would be more suitable for me?
9I'm 44, looking for my first car, living in a small city. It's for daily commuting and family use. Between the Mazda CX-5 2.0 top trim and the Kodiaq 2.0T two-seat luxury version, which one would be more suitable?
10I didn't drive for two days, and when I started the car today, I noticed the engine warning light was on. For the first ten minutes or so, pressing the accelerator only increased the RPM, and the speed stayed below 20. After driving for about ten minutes, when I pressed the accelerator, there was a humming noise, and the speed gradually picked up. However, the fuel consumption display kept changing even when the car was parked or just started and not moving (or maybe I hadn't noticed this before). Can anyone advise what's going on? Has anyone experienced this before?
