When the power tailgate of the 2018 Koleos only opens a crack and requires a second press to open fully, but closes in one go, how can this issue be resolved?
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
4Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
5Hi everyone, I want to ask about my new Model X. When I press the button once, the falcon wing doors open but don't fully extend. It's like this on both sides. I need to press the button again for them to fully open. Is this normal for everyone?
6What could be the issue with the electric sliding door of my Volkswagen Sharan not fully opening or closing?
7Is there anyone who knows what's going on with the electric tailgate making a loud and piercing noise when opening and closing?
8Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
9Does anyone know about the Haval H2? Initially, when you pressed once, it would turn off, and pressing a second time would cut off all power in the car. Now, pressing once turns it off, and pressing a second time puts it in a powered self-check mode. Does anyone know what might be the problem? Has any owner experienced the same issue? Thanks!
10Hello everyone, the power tailgate makes a strange noise when opening and closing. How can I fix it?
