Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
What causes a delay in starting a cold car?
What could be causing the central lock switch on the 2018 Dongfeng Renault Koleos 2.0 to work intermittently? Has anyone else experienced this issue, and how did you solve it?
4Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
5How to solve the issue of no idle speed increase when starting a cold 2019 Renault Koleos?
6HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
7Is there anyone who has experienced noise from the passenger side when turning on the air conditioning in the 2019 GAC GA6? How did you solve it?
8I recently went on a highway long trip, and after just letting the car sit for a day, I'm experiencing delayed acceleration. When I press the gas pedal, I can hear a swooshing sound from the chassis. Is it clogged again? Anyway, the instantaneous fuel consumption has increased, which is really frustrating. Has anyone else experienced this? How did you solve it?
9When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
10Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
