حسين بهاء الدين
حسين بهاء الدين
Mar 6
In my 2013 imported Koleos, the fuel consumption used to be 8-9, but recently it has jumped to 12. I don't know the reason. Could the experts in the group please help and provide a solution? Thank you!
فهد شاكر
فهد شاكر2024-03-08 21:26
Clean the throttle body, or check if the spark plugs need replacement.
Fellow car enthusiasts, does your car take a long time to heat up? It seems like I need to drive 8 or 9 kilometers before the water temperature is sufficient, otherwise I'm hesitant to turn on the heater. If the car is warmed up for a while, it's a bit better. Do you guys have any solutions? 🙏🙏
You can start by calmly explaining the situation to the 4S shop. Let them know that after your recent maintenance, the coolant return hose wasn't secured properly, leading to damage to the turbocharger and causing the car not to start. Ask them to take responsibility for the mistake and discuss possible solutions, such as repair or compensation. It's important to have any relevant documentation, like your service records, ready to support your case.
When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
I need some advice from experts: I have a 2013 1.4T Touran. Recently, the engine occasionally makes a loud noise after starting, and the idle speed is over 1100. But after turning off and restarting, the engine sounds normal, and the idle speed is around 700, back to normal. What could be the issue?
I recently got a 2013 1.4T VW Touran with 110,000 km on it. It's been owned by one person before me. Currently, the big electric fan isn't working, but the small one still is, and the water temperature isn't high. I'm planning to replace it in a few days. The only issue right now is a whistling noise in 5th gear at 70-80 km/h. It doesn't happen in 4th gear, only in 5th when I accelerate, and it stops when I release the gas. 🙂‍?️ Seeking advice from experts—is this a transmission problem?
Renault Koleos
Renault KoleosSAR 82,845 ~ 131,250Gasoline
