How to solve the issue of no idle speed increase when starting a cold 2019 Renault Koleos?
What's the idle speed of your Mazda 3 when starting cold? Mine is over 1000 RPM.
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
Just got it, the engine idle speed fluctuates when cold. Any fellow car owners experiencing this?
4I'm considering getting a Renault Koleos. How is this car?
5Is anyone familiar with solving the issue of idle speed occasionally rising to 2000 RPM and then dropping back down on a stock MG HS? It's particularly noticeable at low speeds.
6What could be causing the central lock switch on the 2018 Dongfeng Renault Koleos 2.0 to work intermittently? Has anyone else experienced this issue, and how did you solve it?
7Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
8Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
9How to solve the issue of no idle speed increase when starting a cold 2019 Renault Koleos?
10Why is my 2018 1.6 manual transmission car having unstable idle when cold started?
