Hi everyone, I need some advice. The central locking system on my 2018 Dongfeng Renault 2.0 Koleos is acting up. Sometimes it works, sometimes it doesn't. What could be the problem?
Master, the right side electric door sometimes responds and sometimes doesn't. After manual operation, it works normally again. I've replaced the lock block, sensor seal strip, and sliding sensor. (290,000 kilometers) Any advice?
How often should the battery of the 2018 Dongfeng Renault Koleos be replaced?
4What could be causing the central lock switch on the 2018 Dongfeng Renault Koleos 2.0 to work intermittently? Has anyone else experienced this issue, and how did you solve it?
5Is there anyone who has experienced a similar issue with the 2017 Dongfeng Renault Koleos 2.0 making a squeaking noise when turning the steering wheel? I went to the repair shop and they said the steering gear needs to be replaced. How did you solve it?
6Can the 2018 Renault Koleos play lossless music from a USB drive?
7What color is the coolant for the 2017 Dongfeng Renault Koleos?
8Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
9I'm considering getting the 2.0 version. Can anyone who has bought it share some advice? Is the power really as weak as people say online?
10Hi everyone, in my second-hand 2014 V60, the manual shift mode can only upshift but not downshift. Is there a problem with the transmission? Any advice?
