عبدالله عبد الغفار
عبدالله عبد الغفار
May 11
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
When driving slowly in the 150ltd, if you hear the sound of the electric pedal retracting or extending, it could be due to a malfunction or a sensor issue. Even if the car doors are properly closed, the motor sound might still be audible. It's best to have it checked by a professional to ensure everything is functioning correctly.
Does the 2014 model with 4 doors have keyless entry?
Hey fellow car enthusiasts, does anyone else have issues with their Haval H7 keyless entry being inconsistent? Sometimes it works fine, but other times it's unreliable. Especially on rainy days, it often doesn't work.
How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
2022 HONGQI HS7 QiChang with five seats, driven 8000 miles. After rain, the keyless entry system failed. The key can only lock and unlock the doors; inside the car, the key is not recognized (both keys have this issue), and the car won't start (even emergency start doesn't work). HONGQI Smart Connection can start the vehicle, but it can't be driven away. The 4S shop inspection indicated a key matching fault, and after re-matching, it worked fine. However, the issue reoccurred 5 days later. What could be the problem? Have any fellow car enthusiasts experienced this? How do you deal with it?
Only the driver's side keyless entry is working, and I've checked the settings, everything seems fine. The auto start-stop isn't activating anymore either, though I don't really use it. Has anyone else encountered the same issues?
Renault Koleos
Renault KoleosBHD 6,373 ~ 12,650Gasoline & Petrol
