عبدالرحمن فواز
2023-06-23 11:38
Will driving 5,000 kilometers without adding a cleaner clog the fuel injectors? Do you need to clean the turbo blades at 20,000 kilometers?
عبدالرحمن فواز
عبدالرحمن فواز2024-08-13 18:23
Thank you to all the car owners.
عبدالرحمن فواز
عبدالرحمن فواز2023-08-15 15:48
Thanks to all fellow car enthusiasts. [Handshake][OK]
حسن مك
حسن مك2023-06-25 08:27
No, no need.
عل عبدالله
عل عبدالله2023-06-25 08:17
No need, use cleaner as needed, not necessarily at 5000.
سلمان ميمون
سلمان ميمون2023-06-25 08:07
Understood. If you have any other requests or need further assistance, feel free to let me know.
Foton Cummins engine, 2.8T engine having diesel entering inside, causing the oil dipstick to rise by two to three centimeters every few hundred kilometers. The high-pressure fuel pump has been replaced, and the injectors have been calibrated without any issues.
For the 2023 Model X, there are several accessories you can consider to enhance practicality beyond the basic seat covers and floor mats, especially for your 5-seater version. Here are some suggestions: 1. **Trunk Organizer**: Helps keep your trunk tidy and maximizes space usage. 2. **Sunshade**: Protects the interior from heat and UV rays, keeping the cabin cool. 3. **Screen Protector**: Prevents scratches and reduces glare on the touchscreen. 4. **Wireless Phone Charger**: Convenient for charging your phone without cables. 5. **All-Weather Floor Liners**: Offer better protection against dirt and spills. 6. **Roof Rack**: Adds extra storage capacity for trips and outdoor activities. 7. **Console Wraps**: Personalizes the interior and protects from scratches. 8. **Portable Vacuum Cleaner**: Keeps the interior clean, especially useful for families or pets. These accessories can improve the functionality and comfort of your Model X.
Asking everyone, with the car being three years old and having 20,000 kilometers, what maintenance items need to be done?
I have a 2015 2.0L automatic model, the second highest trim without a sunroof. The fuel consumption is at 9, which seems quite high. Last year, I had a maintenance check where the throttle body was cleaned, and the spark plugs were replaced. Tires are fine too. The fuel consumption is terrifying—almost 0.7 currency per kilometer. Why is it so high?
Does the Eclipse Cross need a transmission oil change after 20,000 kilometers and four years? Thanks.
Is the third-generation 888 engine, with 70,000 kilometers on it, now burning one liter of oil every 5,000 kilometers? I've always used Castrol Edge 5W40 oil. Does it need a major overhaul?
I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
