avatar-image
عبدالرحمن ستار
Sep 2
Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
نايف حمدان
نايف حمدان2024-09-03 15:16
Just like the operation of spraying windshield washer fluid, pull the headlight lever inward for 50 seconds. It seems like this can turn off the adaptive feature. You can give it a try, but the next time you start the engine, the adaptive feature will be restored. Please refer to the manual for details.
محمد يونس
محمد يونس2024-09-03 09:39
It should be the lever for the lights! Try turning it back and forth; you might have forgotten which one it is. [I want to be alone] The dashboard should display it.
عبد العزيز يونس
عبد العزيز يونس2024-09-03 00:16
Downstairs knows.
