When using Bluetooth to play audio, does anyone else notice the volume is relatively low? With CarPlay and the radio, it feels like setting the volume to 10-12 is enough, but with Bluetooth and AUX, I have to turn it up to 18-20. What's going on here?
I have a basic manual version of the 2011 Touran. The center console only has a radio, and I've been using a Bluetooth adapter through the cigarette lighter to listen to music, but there's often electrical interference noise. I've tried switching 2-3 adapters, but the issue persists. Does anyone have good suggestions? I feel like Android screens priced between 300-500 might not be reliable, and I don't want to spend over 1000 on modifications. How can I use the original car audio system?
4My car is a 2019 JETOUR X90, manual Yuexiang model. Recently, I noticed an issue where the sound is sometimes on and off when I play music through the car's Bluetooth. Sometimes, there's no sound at all. Even when I switch to the radio, there's no sound, although the music on my phone plays normally and I can control it. If I pause on the phone, the car system also pauses. It's quite strange. Have any of you encountered this issue? Thanks for your help 😜
