What could cause the driver's seat to move forward but not backward?
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
Does your C30 have the feature where the seat moves back when the engine is turned off and moves forward when it is started?
What could be causing severe idling vibration?
4What could be causing the engine to make a ticking sound?
5When the old model Vito is at a red light and you shift from N to D, causing the car to lurch forward, what could be the reason?
6What could cause the driver's seat to move forward but not backward?
7What causes the vibration noise in the passenger seat?
8When driving the Tiida, there's always a rolling sound like a water bottle moving back and forth, but there aren't any bottles with liquid inside the car. What could be causing this?
9When you enter the GV80 and the driver's seat adjusts automatically, does the buzzing sound continue for a while after it stops moving? Has anyone else experienced this? Thanks.
10Can the Eyesight cruise control automatically move forward after stopping? Why didn't my car move after the car in front of me started moving the other day?
