سلمان زاهر
2023-06-10 10:01
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
Comments( 17 )
علي مدرسي
علي مدرسي2023-10-24 02:14
Replace the wiring harness connector, but I did it last time and now I still occasionally have this problem.
علي يعقوبي
علي يعقوبي2023-10-23 12:10
Change the plug.
عمر يونس
عمر يونس2023-10-19 09:14
I feel like there are quite a few issues.
خالد نوح
خالد نوح2023-10-17 15:16
I'm just like you, dealt with it once before, and now it's here again [I need some peace].
علي يوسف
علي يوسف2023-10-13 21:25
When I use Bluetooth to play music in my car, the volume is very low. This issue doesn't happen with CarPlay or AUX. Not sure what's going on.
علي لبيب
علي لبيب2023-10-12 23:59
Same question passing by.
خالد هلال
خالد هلال2023-10-09 00:36
Does the loud noise from the navigation system scare you when you reach the destination? Do you also experience this?
20
أحمد تاج
أحمد تاج2023-06-17 08:04
I've changed the plug before.
2
أحمد سعود
أحمد سعود2023-06-15 16:34
You can just replace the waterproof plug, and the 4S shop will do it for free.
نايف جبريل
نايف جبريل2023-06-14 22:42
Use the steering wheel controls to turn the loudspeaker on and off; try to avoid doing it directly when shutting off the engine. Also, avoid using wired CarPlay. Following these two tips, I haven't experienced a system crash in years.
My 10-year-old car makes a strange noise when I accelerate hard or when going uphill. The sound is like "pop, pop, pop." Does anyone know what the issue might be?
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
Geely sometimes has no response when starting, but the dashboard and electrical components are powered. It happens occasionally. Is there a solution?
When the car's steering angle exceeds 100 degrees, the chassis sometimes makes a "ka-ka" sound. What's the issue? It happens occasionally.
I've noticed a "pop" sound coming from the front of the car when it's cold. Once I start driving, everything seems normal. The dealership said they'd need to keep the car there to check it. Has anyone experienced a similar issue? What could be wrong? It's happened multiple times already.
My car is a 2019 JETOUR X90, manual Yuexiang model. Recently, I noticed an issue where the sound is sometimes on and off when I play music through the car's Bluetooth. Sometimes, there's no sound at all. Even when I switch to the radio, there's no sound, although the music on my phone plays normally and I can control it. If I pause on the phone, the car system also pauses. It's quite strange. Have any of you encountered this issue? Thanks for your help 😜
When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
RDX car display screen has no sound while navigating and playing music, and there's no image response when turning right. Can anyone let me know the reason?
While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
