عبدالرحمن وي
2024-03-25 19:23
Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
عبدالله مسعود
عبدالله مسعود2024-03-26 00:24
When the car is cold, there's a noise coming from the brake discs. Also, when going up and down curbs, there’s a noise from the sunroof due to some kind of squeezing. I haven't encountered this before. 😬😬😬
نايف حمدان
نايف حمدان2024-03-25 22:33
When the car is cold, there is a strange noise from the brake discs. Additionally, when going up and down curbs, there is a creaking noise from the sunroof due to pressure. I haven't encountered this issue before.
عبد العزيز يونس
عبد العزيز يونس2024-03-25 20:28
I really can't figure out where this noise is coming from [I just want some peace]
Is there any abnormal noise from the transmission in the 1.6 Explore model?
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
Is there anyone who has changed the rear shock absorbers because of abnormal noise and excessive stiffness?
When driving the Multivan T6, if the electric sliding door makes a squeaking noise on bumpy roads, which sounds like metal friction, what solutions are there?
Hey car enthusiasts, does anyone else notice a squeaking noise with the ID.3 brakes? Especially a "squeak" sound.
Can the rubber bushings be replaced? The car makes a lot of noise when driving over bumpy roads.
I bought a second-hand Kia Sportage that's 10 years old. When going over bumps or speed bumps, the front chassis makes a creaking noise. I asked a repair shop, and they said it's likely the stabilizer bar bushings have aged. Replacing the two front stabilizer bar bushings would cost over 200, but they also mentioned that changing them might not necessarily solve the problem. Do you think it's necessary to replace them?
Hi everyone, I have a rattling noise on the roof. It doesn't make a sound on asphalt roads, but on bumpy roads, it keeps rattling. Has anyone experienced noise from the roof and how did you solve it?
Does your SUV make a buzzing noise from the rear passenger side when driving at speeds of 20-30 on bumpy roads? There's no such sound from the driver's side. Without some music, it's really hard to ignore that noise!
