Is there a tutorial for changing the battery? This morning I got a low battery warning. It's been about two and a half years since it lost power.
My car keeps giving a low battery warning at the back, through voice prompts. Does anyone know what's going on? Thanks.
Hey folks, I need some advice. I just changed my car battery, and the starting power seems strong. But why does it show low battery voltage as soon as I turn off the engine? Even after driving 100 kilometers, it still reports this issue. What's the reason?
4How often should the transmission fluid be changed? It's been almost two and a half years, and I've driven nearly 40,000 kilometers. The dealership suggests replacing it.
5Hey folks, got a low oil warning and the next day it started making noise. Even after adding 4 liters of oil, it's still the same. Any idea why?
6Is your 2021 GAC GS4 Tech Edition still powering the screen after the engine is turned off, taking about two minutes to cut the power? Has this change happened to you as well?
72015 Red Label manual Xiao Er suddenly lost all power and the screen went black while driving, and it wouldn't start. After two or three minutes, it was fine again. Has any fellow car enthusiast experienced the same situation?
8Hey fellow car enthusiasts, my Song Plus flagship model suddenly lost power, but the battery check shows no issues. Has anyone experienced this before? How did you solve it? Thanks in advance for any advice!
9If you left your car in D gear overnight and found it without power the next morning, it could be due to the battery being drained. Does anyone know why this happened?
10The vehicle suddenly lost power on the highway without any warning messages. What could be the issue?
