Is the transmission oil leak a common issue for the January 2019 Diamond Enjoy VI model?
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
Is oil consumption a common issue for the Mitsubishi Eclipse Cross? How should it be repaired?
Is it possible for there to be an oil leak at the connection between the transmission and the engine?
4Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
5Is there any problem with the transmission vent valve oil leak on a 2018 MG ZS automatic? Asking the experts.
6Hey car enthusiasts, I'm considering buying a 2019 CS95 4WD luxury model. Is it worth getting? Any common issues?
7How to deal with a transmission oil leak? Does it affect daily driving?
8Has anyone with the 2019 GA6 changed the transmission oil? Is it necessary to change it?
9Is sunroof leaking and rear door handle not retracting a common issue?
10Is it common for a 2016 Nissan X-Trail with 120,000 km to have the air conditioning leaking refrigerant after two long trips, with a two-month interval? Is it an issue with the compressor or the evaporator leaking?
