How to repair a damaged chrome strip on the front grille, or should I replace the entire assembly?
Can I replace just the headlight adjuster for the March, or do I need to replace the entire headlight assembly?
Where can I buy a foam strip for the front windshield of a Raptor?
Guys, for the Middle East version of the '16, can this footboard be repaired? It's just the outer plastic that's slightly damaged. I don't want to replace the whole footboard.
4The air conditioning internal circulation of the 2016 Hongqi H7 with the chrysanthemum logo is broken. How can it be repaired? Is it that one of the shafts of the air conditioning flap is broken? Do I have to replace the entire air conditioning assembly?
5The front clip of the electric seat adjustment panel is cracked. Do I need to replace the entire assembly?
6How to repair a damaged chrome strip on the front grille, or should I replace the entire assembly?
7How should I handle the maintenance and repair for HiPhi now?
8How much does it cost to replace the front right shock absorber on a 2019 GS5? Should I replace just one or both? 😢
9I've heard that the vacuum pump on the Jeep is leaking oil. I've already replaced two gaskets, but it's still leaking. I've been told that I might need to replace the entire assembly. Is that true? Can fellow car enthusiasts share their experiences?
10Hey everyone, after my 2012 Mazda 6 rear-ended someone, I replaced the entire front end. After the repairs, the gaps are big, and when I'm driving at high speeds with crosswinds, there's no wind inside the car but there's wind noise. What's the issue?
