How do you solve the brake squeal problem? What should be replaced?
What should I do if the brakes on my Maxus T60 feel soft?
Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
4How do you solve the brake squeal problem? What should be replaced?
5What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
6After changing the brake fluid in my GAC GS5, the brakes failed. I thought it might be an issue with the master cylinder, so I replaced it, but the problem still wasn't solved. Can any experts offer some help?
7How to solve the problem of loud noise?
8How many kilometers should the brake pads be replaced on a Smart 453?
9How to solve the problem of burning oil?
10Hey guys, how many liters of brake fluid do you need to replace the fuel?
