avatar-image
عمر قادر
Sep 4
Hey folks, when starting the car cold and switching from P to D, the transmission makes a clunking sound. Also, when parking and switching from D to P, the car lurches forward a bit. Any idea what's causing this?
Comments( 6 )
نايف سيف
نايف سيف2024-11-10 17:02
Even when I press the brakes hard, the brakes on this car don't work well.
علي يعقوبي
علي يعقوبي2024-09-23 23:19
Try this parking sequence: first shift to N, then pull the handbrake, and finally shift to P. I used to have issues with the car lurching, but following this order solved it.
عبدالرحمن ميرزا
عبدالرحمن ميرزا2024-09-21 01:14
When you press the brake with your right foot and apply a little more force, it feels much better.
سعود رشيد
سعود رشيد2024-09-15 18:28
Yes, shifting to D or R gear when the engine is cold can cause the car to lurch forward. However, if you let the car idle for 2-3 minutes to warm up after starting, the issue usually resolves.
حسن بارزاني
حسن بارزاني2024-09-04 23:35
Has anyone experienced the car body shaking when you shift to P gear first and then pull the handbrake on a steep slope? [I want to be alone]
أبشير محمد
أبشير محمد2024-09-04 22:54
I asked the 4S shop about this, and they said gear adhesion is a normal phenomenon.
When the old model Vito is at a red light and you shift from N to D, causing the car to lurch forward, what could be the reason?
Has anyone in the group experienced this issue with a 2019 Patrol, 4.0 Middle East version, after 70,000 km? When switching between D and R gears, there's a noticeable clunk from the chassis. It drives fine on the road, but when changing from forward to reverse, there's a distinct clunking sound.
Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
What could cause the horn to start honking by itself when the car is parked? Any ideas, folks?
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
Hi everyone, I'm a newbie here and I have a question. When you park your Panamera on a slope and put it in P, does it roll a bit and make a loud clunk sound when you release the brake? And when you shift from P to N, is there also a clunk sound? My new car makes a really loud noise. It's scary, I almost thought I got hit.
