Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
4Hello everyone, could someone help me with this issue? When in Park and idling, if I rev the engine above 1600 RPM and then release the throttle, the RPM stays around 1600 for about ten seconds before it drops. This doesn't happen if I don't exceed 1600 RPM. Between 1600 and 2000 RPM, there's a noticeable jolt. Additionally, when shifting gears and slowly accelerating, there's a rattling noise between 1600 and 2000 RPM, but it disappears after 2000 RPM. Does anyone have any insights on this? I would really appreciate it. The car model is a 2016 30T two-wheel drive. Thank you very much!
5Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
6Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
7Why is the idle speed around 600 to 700 RPM?
8The Volvo C30 2.0D has a normal idle speed of 850±20 RPM when in gear, but the idle speed is high at 950±20 RPM when in neutral. What's going on?
9It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
10My Zhilong 2022 model 2.0 has reached 20,000 kilometers. When the engine is cold-started, there's a "dang dang dang" sound at 1500 RPM, but it's gone at 800 RPM. Is it the same for you guys?
