حسين نعيم
2024-03-17 21:14
Hey everyone, do you feel like the accelerator is really close to the floor in this car? With a floor mat, I guess you can't hit 6000 RPM. Are you all experiencing the same thing?
عبدالله مسعود
عبدالله مسعود2024-03-18 01:02
It's quite hard to reach six thousand, haven't tried it yet. 😁😁😁
عبد العزيز يونس
عبد العزيز يونس2024-03-18 00:57
"I want to be alone for a while."
2
When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
Hey everyone, is it normal for the car's RPM to stay around 1200 even when I release the accelerator while driving? The idle speed is only 800 RPM when parked in neutral. Is it the same for you guys?
Hey guys, what kind of floor mats did you get for your car after buying it?
Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
Is your 2015 Jetta also like this, where the RPM only reaches around 3800 when you floor the gas pedal in neutral and doesn't hit 4000?
Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
My 2014 car has 71,000 km on it and there's been a persistent smell inside for a long time. I've removed the floor mats and seat covers but still can't find the source. Do any fellow car owners have the same issue? How did you solve it?
