محمد إياس
2023-12-28 16:04
Have any of you cleaned the throttle valve? Did you do it at the dealership or another repair shop?
Comments( 6 )
حسن سعيد
حسن سعيد2024-01-21 17:01
I've only ever changed engine oil, brake oil, and differential oil. Haven't replaced or dealt with anything else...
نايف جبريل
نايف جبريل2024-01-07 20:05
Behind the engine, near the firewall, a lot of things need to be removed, including the battery bracket, but the price is reasonable, 480.00.
عمر مكتوم
عمر مكتوم2024-01-01 22:17
Has it been washed? Any changes?
عبدالله مسعود
عبدالله مسعود2023-12-30 01:54
I haven't washed it. The throttle of the RDX is quite hidden, it's a bit of a task. If the detection doesn't show the opening is too large, it's not recommended to clean it. You might want to ask the 4S shop how much it would cost. If you're getting it cleaned at an outside shop, remember it needs to match the opening [grin][grin][grin].
طموح خالد
طموح خالد2023-12-28 23:30
Just washed, seems like 376.
عبد العزيز يونس
عبد العزيز يونس2023-12-28 16:41
Throttle body cleaning on an RDX can be a bit of a task since it's not easy to access. If diagnostics don't show that the throttle opening is too large, it's usually not recommended to clean it. You might want to ask the 4S shop for their price. If you decide to have it cleaned at a local shop, remember that the throttle opening might need to be recalibrated.
