فهد كاظم
2024-10-30 22:05
Has anyone with an iPhone 16 experienced issues with charging? I've tried several cables, but it either doesn't charge at all or charges very slowly. Is anyone else facing this problem?
عمر مكتوم
عمر مكتوم2024-11-01 11:31
Some cables don't support charging protocols; Samsung works fine, but Apple doesn't respond. Tested it myself.
أحمد عبد عزيز
أحمد عبد عزيز2024-10-30 22:59
I can't afford a 16 [I want to be alone].
2
Registered in November 2015, 1.5T Luxury version, driven 100,000 km. Recently, when accelerating a bit too hard, it feels like it shifts to neutral; the engine revs, but the dashboard still shows D gear. If I release the gas pedal and wait for a second or two, then accelerate slowly, it goes back to normal. I can't accelerate suddenly, only gradually. Has anyone else experienced this problem? It's been repaired several times but still not resolved.
Is your air conditioning cool enough? Other cars can go down to 16 degrees, but I feel like the Swift only goes down to about 22 degrees. It's not very cool, but not too hot either. 🤦‍♂️
How do you charge your phone? The cigarette lighter USB can't charge my iPhone, but it works with OPPO. Does anyone have any solutions?
Fault code P0504, currently gears 1, 2, 3 are fine, but when switching to 4th gear, the car loses power when pressing the accelerator and doesn't accelerate. The RPM drops very slowly when pressing the clutch. Has anyone else experienced this?
The maintenance manual for the Arrizo 5 suggests adding 4.7L of engine oil, but most services on the market typically charge based on 4L. Has anyone tried only adding 4L?
How to solve the seal problem? Has anyone else encountered this? It drifts to the right quite severely. Kugou can't open. There's a strange smell from the air conditioning. The steering wheel vibrates a lot, and in winter, the range is only 60-65% of what's advertised.
Why can't CarPlay connect? I've tried several different cables but still can't connect. Any experts here to help?
I can't charge my electric Lavida, thought it was a grounding issue (there's a grounding wire left by the developer in the electrical box), so I connected it to the ground as well, using two 60cm grounding rods and a 50cm grounding angle iron, but it still sometimes charges and sometimes doesn't. Even the portable charger doesn't work. It's driving me crazy. When I took it to the 4S dealership, it charged fine. They updated the car's system, but it still won't charge at home. I tried two neighbors' charging stations, but it still won't charge. What's going on? Has anyone experienced something similar? It's been over 3 years and 50,000 km.
Has anyone experienced this situation? (The lights flicker while driving, the battery is fine, it's not the automatic headlights, and it doesn't happen very often. A roadside repair shop moved the headlight's fuse, but the problem still hasn't been solved.)
Hi everyone, I have a 2015 Volkswagen Jetta with a manual transmission. I'm having trouble turning the key in the ignition; it takes several tries and some jiggling to get it to turn. Does anyone know what might be causing this? Any advice would be appreciated. Thanks!
