أحمد سعود
2023-12-21 00:01
Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
عمر مكتوم
عمر مكتوم2023-12-21 12:48
I saw in other people's videos that the launch control makes a sound.
عبدالله مسعود
عبدالله مسعود2023-12-21 03:58
Share what happened next 😁😁😁
عبد العزيز يونس
عبد العزيز يونس2023-12-21 00:15
The details of the case have been announced downstairs.
Hey car enthusiasts, my 2017 4WD Smart Drive version stalls when I shift to Neutral (N) or Park (P). Has anyone else experienced this issue?
Is it a problem if my GAC GS5 occasionally shows error codes? How can I fix it?
Hey car enthusiasts, when I put my 4WD on a lift, the front wheels spin but the rear ones don't. After a while, it shows a "4WD Overheat" warning. But when I drive on the road for a bit, the error code disappears.
What could be the issue if my manual Jetta's transmission makes a rumbling noise, but the sound disappears when I press the clutch?
Hey guys, how do you avoid the small battery draining and getting error codes when tinting? Should I keep the car running or turned off? I noticed that the car doors are open during the tinting process.
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
Anyone else experiencing occasional rattling noises from the 24 model's dashboard? It sometimes goes "dang dang dang," but when I take it to the dealership, the noise disappears and they can't find the issue.
I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
