عبد العزيز غازي
2023-10-31 21:46
After washing the car, the front door windows won't roll down. The buttons aren't responding. Has anyone experienced this before?
عبدالله مسعود
عبدالله مسعود2023-11-01 00:52
Looks like the plug got damp. 😬😬😬
عبد العزيز يونس
عبد العزيز يونس2023-11-01 00:16
The plug is probably damp.
Is it a two-door four-seater car? Do you get in by folding down the front passenger seat?
The passenger side window suddenly won't go up or down, and the driver's side window has broken once before. I can't really vouch for Iveco's quality!
Why do you have to press the rear window button once before starting the 2013 GS5?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
Today, I suddenly found that the driver's side window won't roll down, but I can hear the motor running. What could be the issue?
Does anyone know why the rear window won't go up or down? Thanks!
What could be the reason that when I press the key, the car doesn't respond and the doors won't open?
The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
