فهد سالم
2021-12-27 14:09
Guys, does the RCZ only require 95 octane fuel?
عمر فخرو2022-04-30 08:18
It is required to only use 95 octane fuel; otherwise, it may affect the engine.
عبدالرحمن وليد2021-12-29 21:26
Both 95 and 98 are fine.
Hey guys, does this car require 95 fuel?
Do I need to fill the P1 with 92 or 95 octane fuel?
Does the 2015 automatic Touran need to use 95-octane fuel?
4Does the 2011 MDX use 92 or 95 octane fuel?
5Is the Scirocco only able to use 95 octane fuel?
6Can using 95-octane fuel provide a power boost for a vehicle like the Kia Sportage that specifies 93-octane (now equivalent to 92-octane)?
7Is the 2024 BRZ only compatible with 98 octane fuel?
8In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
9I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
10Are you using 95 or 98 octane fuel?
